Dev-1997
Since our previous attempts to reset the USB driver were unsuccessful, I would like to help you upgrade the firmware of the onboard Geehy Link as a next step.
You mentioned earlier that you have a fully functioning standalone Geehy Link Debugger. I highly recommend using it to connect directly to the onboard Geehy Link’s own SWD interface (please ensure it is connected to this specific interface, rather than the simulated SWD lines connected to the main MCU).
By doing this, you will be able to unlock and access the APM32F103CBT6 chip and flash its firmware to a newer version that supports CMSIS-DAP V2. You can refer to the instructions and the necessary program files provided in the link below to flash the firmware yourself:
https://www.geehy.com/uploads/tool/GEEHY-LINK%20Upgraded%20%20Guide%20V1.0.zip
For some context, based on the screenshot you provided, the key difference between your software version and the one our engineers use is the absence of “WinUSB”. If the firmware is flashed successfully, you will be able to use an upgraded version of the onboard Geehy Link that includes this feature.
However, if this process still does not work, physically disconnecting this daughterboard might be the smartest decision moving forward.
