madhusudan I have ticked the option on reset and run in options but mcu not running after power cycle. after many power cycles it runs the code.
David madhusudan Are you using our SDK examples directly? If it’s been modified, go into debug, run the code, and see if there’s any code that’s taking a lot of time that’s causing you to not see the behavior your code is setting up.
