Lately I’ve been asked about the way to learn MCU easily, especially for PM and Sales Engineers that are not keen to EE terms, I just asked my friend ChatGPT about it, and it perfroms perfectly to analyze datasheets and SDK codes!
From GPT’s POV, this is what it can do for us:
When analyzing datasheets in PDF format and SDK libraries based on C code, I can assist with the following tasks:
Datasheet Analysis (PDF)
Extract Key Information:
- Identify and summarize the core features and specifications of the MCU, such as processor type, memory size, clock configuration, I/O capabilities, and peripherals.
- Extract information about electrical characteristics, including power requirements, voltage ranges, current limits, and thermal specifications.
Peripheral Overview:
- Explain the different peripherals available in the MCU, like GPIO, ADC, UART, SPI, timers, and PWM, and how they are used in embedded systems.
- Provide insights into pin configurations, addressing multiplexing, and which pins support specific features (e.g., analog functions, communication interfaces).
Clock Tree and Power Management:
- Describe the clock system in detail, including different clock sources, PLL configuration, and how various buses (AHB, APB) are clocked.
- Discuss power consumption and available low-power modes, helping to understand how to optimize energy efficiency in designs.
Interrupts and Memory Layout:
- Break down the interrupt system (e.g., NVIC) and external interrupt handling.
- Review memory map (RAM, flash, system memory) and address allocation for different peripheral regions.
Functional Descriptions:
- Provide an overview of the architecture, bus systems, and peripheral control registers as explained in the datasheet.
- Help in understanding the startup configuration and boot modes (e.g., from flash, SRAM).
Hardware Interface Design:
- Guide you through external hardware interfacing, such as sensor connections, communication bus wiring, and GPIO configurations.
SDK Library Based on C Code
Code Understanding:
- Analyze C code within the SDK library, explain its purpose, and help understand how different modules interact.
- Identify common functions for initializing hardware peripherals (e.g., GPIO setup, UART initialization, timer configuration).
Peripheral Setup and Use:
- Break down how peripheral drivers are used in the SDK (e.g., initializing and configuring ADCs, UART, SPI).
- Explain low-level hardware access code and how to interact with registers directly for advanced use cases.
Code Optimization:
- Suggest ways to optimize SDK code for better performance, lower power consumption, or enhanced system reliability.
- Guide you in debugging and improving the efficiency of C code (e.g., optimizing interrupt handling or DMA transfers).
Configuration and Initialization:
- Help you configure the system clock and power settings using the SDK, explaining initialization functions and settings that affect the MCU’s operation.
- Provide examples or modifications for initializing specific peripherals like timers, communication interfaces, and analog-to-digital conversion.
Example Code and Tutorials:
- Write or modify example code snippets based on your needs (e.g., setting up UART communication, configuring an ADC to sample a sensor).
- Walk through common embedded software patterns used in the SDK (interrupt service routines, peripheral handlers, etc.).
Integration with Hardware:
- Explain how to interface specific hardware components (like sensors, actuators, or communication modules) with the SDK, writing necessary code for interfacing and troubleshooting.
Here’s what I get from GPT 4 when I am asking for the clock resources of APM32F103:
The clock tree of the APM32F103xB MCU is designed to distribute various clock signals throughout the system, ensuring proper operation of the core, peripherals, and communication modules. Here’s a detailed description of the clock tree:
Clock Sources:
- HSI (High-Speed Internal Oscillator): An 8 MHz RC oscillator used by default at system startup.
- HSE (High-Speed External Oscillator): An external clock source, typically a crystal oscillator, with a frequency range of 4 MHz to 16 MHz.
- LSI (Low-Speed Internal Oscillator): A 40 kHz RC oscillator used for low-power operations, like the independent watchdog (IWDT).
- LSE (Low-Speed External Oscillator): A 32.768 kHz crystal oscillator typically used for the real-time clock (RTC).
PLL (Phase-Locked Loop):
- The PLL can use the HSE or HSI as input and can multiply the frequency for different internal clock domains.
- The PLL allows for a frequency multiplication factor, making it possible to scale the system clock (SYSCLK) to a higher frequency, up to 96 MHz.
Clock Distribution:
- AHB (Advanced High-performance Bus): The AHB bus is the main system bus, which connects to the core and various peripherals. It can be configured with a prescaler to adjust its frequency, with a maximum frequency of 96 MHz.
- APB1 and APB2 (Advanced Peripheral Buses): The APM32F103xB has two APB buses:
- APB1: Supports lower-speed peripherals and operates at a maximum frequency of 48 MHz.
- APB2: Supports higher-speed peripherals and operates at a maximum frequency of 96 MHz.
- Both APB buses can have their frequencies adjusted using prescalers.
Clock Sources for Peripherals:
- SYSCLK: The system clock, typically set to 96 MHz, drives the core and most peripherals.
- FPU (Floating Point Unit): If present, it runs at the same frequency as SYSCLK or a fraction of it.
- USB Device (USBD): Requires a dedicated clock of 48 MHz, which is derived from the PLL or an external source.
- Timers (TMRx): These timers can use different clock sources, either from the AHB bus or APB buses, with additional prescaling.
- ADC: The ADC clock can be derived from SYSCLK, with prescalers to adjust the frequency as needed for analog conversions.
Clock Failover:
- If an external clock (HSE) fails, the system will automatically fall back to using the internal HSI oscillator as the clock source.
RTC (Real-Time Clock):
- The RTC can be clocked by the LSE oscillator (32.768 kHz) or the LSI oscillator (40 kHz) for low-power applications. The RTC is capable of running independently of the main system clock, powered either by the main supply (VDD) or the backup supply (VBAT) when VDD is off.
You can tell how efficient this can be, and many AI tools are supporting MCU IDEs like Visual Studio Code, I’ve been trying Copilot and some tools in China, and I am amazed by the canvas functions that shows the result quickly, and how accurate AI is naming variables and writing allocations.
