Encoders are critical in industrial automation and smart manufacturing, offering high precision, real-time feedback, and intelligent control. They are widely used in robotics, CNC machines, elevators, new energy systems, and more.
To meet the needs of the smart industry, Geehy offers a magnetic absolute encoder solution based on the APM32E030 MCU. It provides high-precision measurement with low cost and flexible integration. With rich on-chip resources, it supports protocol conversion, real-time data processing, and algorithm compensation, improving system performance in applications like servo motors, robotic joints, AGVs, robotic arms, CNC machines, and textile machinery.
APM32E030 Encoder Solution Overview
This solution utilizes the APM32E030 basic extended MCU to implement a 17-bit magnetic absolute encoder, ideal for angular position sensing in both industrial control and consumer electronics.
Solution Features
- High precision: 17-bit single-turn resolution; angular accuracy: <±0.5° (before calibration), <±0.07° (after calibration)
- Low power consumption: Multi-turn tracking with <30μA standby current; battery life >5 years (1100mAh capacity)
- High-speed communication: RS485 up to 5Mbps for low-latency real-time transmission
- Compact design: PCB diameter as small as 35mm, ideal for 40mm flange servo motors
Solution Functions
- Single-turn: Real-time position feedback
- Multi-turn: Retains position during power loss
- EEPROM: 1KB read/write support
- Alarm: Warnings for battery, weak magnetic field, voltage, overflow, and turn errors
Solution Advantages
- High performance: Arm® Cortex®-M0+ core, up to 72MHz
- Ultra-low-power modes: Stop at 17μA, Standby at 5.4μA
- High-speed UART: Up to 6Mbps, compatible with 2.5Mbps/5Mbps encoder protocols
- SPI speed up to 18Mbps for rapid chip communication
- Compact QFN28 package (4×4mm)
Speed Test Results
APM32E030 Chip Features
- Arm® Cortex®-M0+ core, up to 72MHz, with 5-channel DMA
- 64KB Flash, 8KB SRAM
- Analog peripherals: 1×12-bit ADC
- Communication interfaces: 2× USART, 2× SPI, 2× I2C
- Packages: TSSOP20, QFN28/32/48, LQFP32/48/64
- Excellent scalability and portability
Geehy offers diverse MCU solutions to support encoder upgrades and Industry 4.0 transformation, meeting various application needs and driving innovation in the encoder market.
Protocol Conversion Type
Entry-Level Encoders
- Types: Magnetic absolute (≤16-bit resolution), Optical absolute (≤20-bit resolution)
- Geehy Part: APM32E030K8U6
- Features: Low power in Stop/Standby modes
- Advantages: Cost-effective for low-resolution applications
Mid/High-End Encoders
- Types: Magnetic absolute (≥16-bit resolution), Optical absolute (≤20–26-bit resolution)
- Geehy Part: APM32F103TBU7
- Advantages: Suitable for mid/high-end uses, compatible with mainstream solutions, proven in large deployments
- Geehy Part: APM32F402TBU7
- Features: Optimized low power in Standby mode
- Advantages: Lower power, excellent cost-performance, ideal for new designs
Direct Signal Acquisition
- Type: Absolute encoders with independent position decoding
- Geehy Part: G32R430 Series (Coming in 2025)
- Features: 16-bit high-precision ADC, fast processing, low power, supports multiple protocols
- Advantages: Enhances in-house development, flexible design, cost-effective
