Ever spent hours debugging an issue that turned out to be a simple clock misconfiguration? We’ve all been there. The clock system is the heartbeat of your MCU, and getting it right is critical.
That’s why we’ve put together a straightforward guide on High-Speed Clock Configuration for our APM32 family. We walk you through the entire process, from choosing your source to setting up the PLL and peripheral clocks, all using the APM32 standard library.
Whether you’re a seasoned pro needing a quick refresher or just starting with APM32, this one’s for you.
