PGuardia
hi Pau, it should be possible to resolve your issue by referring to this post:
Additionally, since you are using the APM32F4 configuration file (.cfg), there may be compatibility issues with the G32A MCU. It might help to double-check if there is an updated or more suitable configuration file for G32A MCUs or try modifying the APM32F4 file to match the G32A environment.
If the issue persists, I recommend sharing the exact error message here so we can provide more targeted support.
(Please kindly note that we are currently on our Spring Festival holiday, so there may be some delays in responses. In the meantime, you are welcome to use the AI assistant on the right side of our community page for any temporary issues.)
